Threads: 50
City: Apple Creek
State, Province, Country: Ohio
I just finished re-stuffing the e-caps, and a couple Bakelite blocks that were noticeably shot. After that I powered up the set with all the tubes expect the 5Z3 rectifier. All went well so I powered up again with the rectifier in place and the set came alive -sort of-. I got some buzzing and whistling from the speaker. Made me feel better that the set wasn't deaf. Now to finish recapping the set before the next power up.
During the full power up the Shadow meter even seemed to function. I could see the vane moving with the sound coming from the speaker.
(This post was last modified: 04-04-2013, 12:04 PM by ipwizard.)
Threads: 567
Nice....I hope the pleasure is proportional to the chassis's size
Threads: 50
City: Apple Creek
busy re-capping today, and I come across a cap #40 on the schematic. It's value is .00125uf (1250pf). The replacement I have for it is .00150 (1500pf) will this be ok. I'm not sure if its critical to get the value of this cap as close as possible.
[Image: http://i1129.photobucket.com/albums/m501...bfebeb.jpg]
Thanks
(This post was last modified: 04-05-2013, 12:27 AM by ipwizard.)
Threads: 567
I think here it is OK to use 1.5nF.
Threads: 268
Hey Mike,
Your going foreign on us again!!!! NF
We got to get together sometime
soon my friend.
Threads: 50
City: Apple Creek
Quote:I think here it is OK to use 1.5nF.
Thank, ill use what I have and hope for the best.
I agree with Morzh, I don't think it will hurt. Let us know how it goes.
Threads: 268
Worst case the osc won't run or it may shift the frequency a little. If it is running I wouldn't lose any sleep over it. Just reset the fq
Threads: 18
Probably .001 mfd would work just fine. Need to do an alignment anyway when you get done recapping and recarbing the set.
Threads: 50
City: Apple Creek
Thanks all. Hopefully I will be mostly done with all the re-capping this weekend. I have found a lot of resistors that are way out of spec (+-20%) in this set. So they are getting replaced as I re-cap.
Threads: 50
City: Apple Creek
Finished the recapping last night. Powered up and it sings. The tone switch has something funky going on with it though. When moving the tone switch the sound will squeal, and pop and carry on until you get it just right. I sprayed it and the band switch with deoxit and let it sit over night we'll see if that made a difference tonight.
I have to say from the few minutes I had the set playing that it is a very sensitive set. I suspect it will be a very good performer after an alignment.
Threads: 50
City: Apple Creek
Tone control issue.
In two of the positions the tone control works as it should, in the other two positions the sound will squeal, high high pitch. There are two 4meg resistors that are measuring 5.2meg. Im going to swap these for 3.9meg.
Anyone have any idea what I should check? I have replaced all the caps with the proper values except the mica's.
[Image: http://i1129.photobucket.com/albums/m501...b33490.jpg]
Thanks
(This post was last modified: 04-15-2013, 05:26 PM by ipwizard.)
Threads: 14
City: Irvington, NY
I would not be too concerned about replacing the 4 meg resistors. There only purpose is to act as bleeders for the tone control caps (.01 uF and 3000pF) and their value is not critical. They prevent any leakage from building up a charge on the caps and causing a pop noise when the tone control is rotated which grounds the cap in that switch position.
Do you have a tube shield on the 77 first audio tube? It is right next to one of the output tubes and the grid cap lead is very sensitive to stray signal pickup. The grid cap lead should be inside the tube shield. Had the same type of squealing problem with a model 610 where the 75 audio stage is right next to the 42 output tube. Putting a shield on the tube with the grid lead inside cured the problem.
Threads: 268
When you get it playing properly I'm curious how well it works?? I just picked up one and a half 116X myself. Haven't had a chance to go though it but it looks to be a really outstanding set be looking at the diagram. It one has been serviced but I'm not sure if it is going to need some more going over. So now I have 116X, 37-116X code 121 and a 37-116X code 122. Think I'm going to have to sell some sets as I'm running out of room. It's great fun!!!! I think I hear that the 37-116 is a better sounding set than the 38-116. I think I'll stop with these three although I would like to get a 680.
Threads: 50
City: Apple Creek
Quote:Do you have a tube shield on the 77 first audio tube? It is right next to one of the output tubes and the grid cap lead is very sensitive to stray signal pickup. The grid cap lead should be inside the tube shield. Had the same type of squealing problem with a model 610 where the 75 audio stage is right next to the 42 output tube. Putting a shield on the tube with the grid lead inside cured the problem.
That was the issue. i put all the tube shields on and that fixed the tone control issue along with the "birdies" while tuning. many thanks!
The part/tool you get from HD is inside the plastic, like in a bubble.RodB — 07:17 PM |
Got it. Still did not get the "Bubble" part.morzh — 07:10 PM |
No Mike. Clear plastic from the packaging of items you buy at Home Depot, the ones you can't open without a hack saw or ...RodB — 05:48 PM |
Philco 89 indicator light.
Well thankfully that did not happen.Jim Dutridge — 05:21 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!morzh — 02:39 PM |
46-1201 Trip Switch Spring
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.morzh — 02:37 PM |
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. ...ConcernedFeller — 01:46 PM |
I am late to this post, amazing amount of work for a speaker Mike. You must like the challenge. I have a speaker from an...Paul Philco322 — 01:04 PM |
Mike, give this site a look for your spider. Can't hurt.
Take care and BE HEALTHY! -GaryGarySP — 12:41 PM |
There are currently 10628 online users. [Complete List] » 2 Member(s) | 10626 Guest(s)
