Crosley 88TC
Started on Crosley 88TC. What is the wattage of resistor #52? ( wirewound two section, 80 and 18 ohm) This is enclosed in a metal tube on top of chassis. Thanks for the help.
Joe
http://www.nostalgiaair.org/resources/650/M0003650.htm
Ohm's law brings it out to about 10 watts. But go at least 20 for safety and heat factors.
Hopefully can get started shortly on the radio.
Joe
There are currently 9782 online users. [Complete List]
» 3 Member(s) | 9779 Guest(s)
