Is the Philco 39-25T model the same exact chassis as the 39-25XF console? Can I put a 39-25T chassis into a 39-25XF console cabinet?
Thanks
Chris
Yes, and yes. Of course the console uses a larger speaker than the table model does... Icon_smile
Buy It Now, Chris, before I do! Icon_lol
Thinking about it Ron but by the time I decided it will probably be gone. I have a lot of projects right now. The reason I asked is because I have the console version and have not finished restoring it yet. Will let you know if I break down and buy it. The price is right!
thanks
Chris
It's gone...you snooze, you lose... Icon_lol (No, I didn't buy it.) Icon_smile
Ron,
I know I did it again! Oh well have enough projects for know but the tubes were probably worth that!
Chris
Philco 91 Tuning Condenser
There are currently 10039 online users. [Complete List]
» 1 Member(s) | 10038 Guest(s)
