05-06-2013, 08:56 PM
Does anyone know the size of a38-116 radio.
Thanks
Thanks
38-116
Thanks
05-06-2013, 10:15 PM
Big
![]() But even more important, heavy.
05-06-2013, 11:58 PM
About 2' deep, over 3' wide, and over 4' tall.
Regards Arran
05-07-2013, 10:27 AM
My 38-116 measures:
Width 27.5 in. Height 43.5 in. Depth 18.5 in.
05-07-2013, 11:28 AM
Thanks
I am thinking about buying one need to know if it would fit in my wife's HHR Vinzer
05-07-2013, 02:17 PM
I know which one you're thinking about buying...
![]() I was going to bid on it myself, but meh, I don't really have room for it. So, good luck to you. Bid early and bid often. ![]() If your HHR's back seats are removable or can be folded down, you can probably get the thing inside there. -- Ron Ramirez Ferdinand IN
05-07-2013, 05:33 PM
Anything else I need to know before I pickup the radio how is the chassis is held in And the best way haul it?
I will have a lot more questions when I start working on it. Vinzer
05-07-2013, 05:42 PM
What ever the answer is to that question, always remember that the last guy that worked on it probably did not put all of the mounting hardware back. Many chassis are loose - and should not be. Check before you move it.
And, don't drag the radio back down over the car's carpet. It is a good way to remove veneer.
05-07-2013, 05:58 PM
Ron
Your right about which radio it was to bad 5 knobs are missing and one wrong tube shield and one missing but the grill cloth looks Fair. Vinzer
05-07-2013, 07:43 PM
Vinzer, congratulations!
![]() ![]() Phlogiston is correct - don't drag that cabinet back down across your HHR's carpet. Been there, done that, lost the veneer to prove it. ![]() -- Ron Ramirez Ferdinand IN
05-07-2013, 07:50 PM
Oh, and by the way - the oddball tube shield in the RF unit is not the correct one, but isn't far from the original as the original was aluminum with a flange on top, cut out for the grid cap wire. Don't ask me why they used one aluminum tube shield, but they did. Every 38-116 I've ever seen had that oddball tube shield.
I've been thinking that if I ever decided to get another 38-116, that it would be one with the "Ten Millionth" replica tag. But since Kutztown is only a couple days away, plus really no room for more consoles (and I've already made a deal to bring a console home from K-town, not a 38-116 though)...Just be sure and share lots of photos of your new prize with us! ![]() The listing has ended, so here it is: http://cgi.ebay.com/251269278031 -- Ron Ramirez Ferdinand IN
05-07-2013, 08:48 PM
I bet that aluminum tube shield will hard to find.
Idon't know about pictures I have never done that but will try to. I wonder how this will come pair to my sparton 1466 it has a 12" and two 5" speakers and variable if band with. Vinzer
05-07-2013, 08:59 PM
Thanks for info on hauling.
Do I just pull of tuning knobs to remove chassis and any mounting screws? Thanks Vinzer
05-07-2013, 09:02 PM
Looks like they also used a square shield for the RF stage.Here is a photo from another ebay listing:
http://i.ebayimg.com/t/ANTIQUE-PHILCO-38...y-HtRYvmC/$T2eC16N,!y8E9s2filQoBRYvmBYv5w~~60_57.JPG?rt=nc
05-07-2013, 09:07 PM
That square one would a lot easier to find.
vinzer
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
