Philco 37-84 restoration
Well, friends.
The restoration has finished. You know how it got this radio to my hands. This was very poor on the front.
[Image: https://dl.dropboxusercontent.com/u/7295...15post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...orpost.JPG]
The problem was getting the typical photo finish, in the early thirties. Without this the radio will not get to have the look of his time.
Luckily, my friend Terry of the Phico Phurum, send me a scan of your Philco 37-84. He sends me in two parts because it was impossible to do a full scan.
[Image: https://dl.dropboxusercontent.com/u/7295...l1post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...l3post.JPG]
Now the job is to unite the two parts, using software such as Photoshoip and Ilutrator.The mission is to get one piece and that the lace pattern.
[Image: https://dl.dropboxusercontent.com/u/7295...ucpost.jpg]
We print on thin paper digital image. Using a glue dissolved in water, got hit the paper layer on the front. As you can see, we have a uniform image, cloning the colors. So, once attached to the front we cut the holes in the speaker grille and knobs.
[Image: https://dl.dropboxusercontent.com/u/7295...t2post.JPG]
And we began to cut
[Image: https://dl.dropboxusercontent.com/u/7295...r1post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...3print.JPG]
finally cutting has finished
[Image: https://dl.dropboxusercontent.com/u/7295...r5post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...r4post.JPG]
Looks like you're on the way!!Icon_surprised
Icon_thumbup
Beautiful! Just like a brand new 37-84B!
OutstandingIcon_thumbupIcon_thumbupIcon_thumbup
M R Radios   C M Tubes
Here you can see pictures of the radio already completed
[Image: https://dl.dropboxusercontent.com/u/7295...01post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...41post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...31post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...71post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...91post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...11post.JPG]
[Image: https://dl.dropboxusercontent.com/u/7295...21post.JPG]
You can see more photos in the Picasa album.
This is the limk
https://picasaweb.google.com/10453952194...co37841936
Mine just sez (image philco post 101 jpg) where a pic should be???
Finally my old laptop started working and it came up with the pics. Gosh the front looks just like my 37-33!! Great job!!
Very nice job!!Icon_thumbupIcon_thumbup
There are currently 11185 online users. [Complete List]
» 3 Member(s) | 11182 Guest(s)
