Push on/off switch
Does anyone know of a good alternative replacement for the push on/off power switch for table models like 41-245. My current project had had it conveniently bypassed with a lovely toggle switch prior to me, and the 'guts' of the original switch are missing - the PB and rod are still in the push button rack but not connected to / containing anything. I'd like to restore this model to its original state, but I haven't found any replacements. Any suggestions?
Hi
You will find some good information on this subject as discussed in these previous threads on the Phorum:
http://www.philcoradio.com/phorum/showthread.php?tid=89
http://www.philcoradio.com/phorum/showth...hp?tid=718
Good luck with your project.
Ron- Thanks, yes, I did not search back far enough. I'll post my solution when I am happy with it.
There are currently 3680 online users. [Complete List]
» 3 Member(s) | 3677 Guest(s)
