Philco Model 20
I recently purchased a Philco Model 20 from a local Salvation Army store.
I powered it up with a dim bulb and variac to be safe. It has audio with no hum associated with bad filter caps and it doesn't smoke (a good thing)
but it's not picking up any stations. Not bad for something 83 years old.
It has a wire for an antenna.
Pete
Schematic and other info here: http://www.nostalgiaair.org/PagesByModel...029582.pdf
It is recommended that you change out all the electrolytic and paper capacitors, and it is easy and cheap enough to replace the carbon resistors (many of which will have drifted way up or become otherwise tempermental) at the same time before powering the set up again. Any rotted out or ratty wires including the line cord should also be replaced as well.
Then let's see what you have.
Would also recommend installing a fuse inline before the switch. Better to see a two dollar fuse turn to toast than a power transformer. Take care. Gary
The Philco 20 has large paper capacitors for filters, likely contained inside a tar filled can somewhere on the chassis along with several bypass capacitors. These capacitors last longer then electrolytics and tubular paper caps but the set is over 80 years old now so one or more of these may have failed causing no reception. Also sometimes the Model 20s can have one or more of the RF coils fail causing a dead radio, they can be checked for continuity with an Ohm meter. Like many radios of this era another common failure is the audio interstage transformer going open on the primary side.
By the way...welcome to the phorum. I'm re-building a Model 20 also, but not in any hurry. Tons of posts here to help you rebuild the components, and very friendly members to help when you get stuck. Take care. Gary
Hi Pete,
I've recaped 2 of the model 20s. The large filter can is not too bad to add in the new caps, right in the bottom cover. Snipping the wires back you should have enough room.
That would be the first step, and you just might receive stations after that step. Then, on to the other cap and out of spec resistors.
A fuse would be fine, in case something this side of the primary shorts out. But if something in the secondary like the filters shorts out, the fuse might not 'see' the current draw of the secondary, and continue to self destruct.
I have a couple of photos of how I installed the new caps, I just have to find the image in one of the older posts. You don't have to use electrolytics like I did, you can use film caps (non polarized) ad they will work fine. I used them on the second 20 I recapped.
So, you heard no hum but it had audio? Just white noise, or?
I'll check back.
Gary.
If it were mine I would use the non polarized poly film capacitors inside that can just so you don't have to mess with it again, they take up more room then electrolytics but there is more then enough room in that can for them, though you may need to remove the old caps to do it.
It was "white noise", Gary.
If you are getting white noise, it seems like everything past the detector stage is working. My guess is that you have an open winding on one of the RF coils. As Arran said, those coils are notorious for going bad due to corrosion of the fine gauge copper wire.
With the radio unplugged, you might try checking each coil winding for continuity with an ohmmeter. Here is a link to the schematic and service info for the set:
What value capacitors should I use in the power supply?
The cap values are posted on the schematics on these pages:
http://www.philcoradio.com/tech/schema.htm
There is one for an early and another for a late Model 20 philco, I don't know which yours is.
Ok, the values I found on the schematic are 1.0, 1.0, 1.5 and 0.13
I agree with Arran...use the non-polarized poly film caps. The .13 might be a little hard to find, but a .15 will work just fine. I used 2 watt resistors for my replacements. I think you will find they will all have drifted up in value over the years. Most of mine were nearly double their resistance values listed. Take care. Gary
The working voltage for these caps I believe should be 450 volts or higher.
If you go with the non polarized caps they come in a standard 630v rating. These will work great and last forever.
There are currently 5177 online users. [Complete List]
» 5 Member(s) | 5172 Guest(s)
AvatarAvatarAvatarAvatar
