Philco 15X cabinet dis-assembly
Have any of you ever restored one of these cabinets? In order to adequately apply lacquer to the control panel, columns, and sound-board, the cabinet should be disassembled. BUT so far I have not figured out how.
Suggestions?
I've tried to dismantle my 15DX with no luck so far. I removed a bunch of wood screws which did loosen the top portion up, but not enough so that it will come off Icon_confused
The sound board should come out, the columns are likely doweled in place so it's likely a chore to get them out. The control panel may or may not come out easily, if they were kind they would have only used screws, if they were not kind they may have used a blob of two of hide glue as well.
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
There are currently 2313 online users. [Complete List]
» 1 Member(s) | 2312 Guest(s)
