37-675 re-cap
Hi Guy's,
Looking at re-capping my 675 chassis, and noticed that electrolitics are not marked as far as voltages on the schematics.
Does anyone know what the corrct voltages are, or can I just use 450 volt for all?
murf
Those on my Philcos were mostly 475V but I use 450V across the board so far.
If you are looking at the rectifier filtering cap and B+ caps.
I think that 450V caps will be fine, as the new caps handle voltage better.
BUT... you might want to actually measure the V present there to be sure. Since house voltage is now in the 120-125V range the actual V present may be much higher than what is was using 110 or 115V that the set was designed for.
The solution IF this is true is to either use 500V or 600V caps OR use a system to reduce the voltage going into your set to 110-115V.
Got it.
Thanks for the help.
murf
How about the odd value dogbone resistors?
I have found that some of them are not available in the value specified on the schematics.
Is it ok to go to the next lower or higher value, or do I have to stack them to get the closest value?
Still learning a radio at a time.
murf
Should be ok. I think the resistors in the set are 20 percent so that give you a pretty good range to choose from.
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
There are currently 2393 online users. [Complete List]
» 3 Member(s) | 2390 Guest(s)
