ID this set?
On the road today. No reference books
Anyone know what model this is?
my guess:
Model 40-190XF
http://philcoradio.com/gallery/1940a.htm#ae
[Image: http://philcoradio.com/gallery/images/trans.gif]
-Mars
Thanks!
Nice looking cabinet. Not what I usually see around here.
Tim
Concur. Nice sounding set, too.
Philco 91 Tuning Condenser
