38-12 antenna coil
Finally had a chance to play with the 38-12 for a bit and ended up winding some #34 wire on the open oscillator coil I had and fired up the set. While that seems to work fine , the primary on the antenna coil is open. As luck would have it, the junker set has a bad one too (remind me why I bought the junker set). Has anyone used the universal antenna coil that AES sells? I tried finding the break without luck and there are far too many turns for me to want to even attempt to rewind it Icon_mad
Hi Tony,
I have used a universal coil on a Dumont 'picture frame" set a few months ago. It had been robbed from the chassis when I bought the set.
I replaced the 4 termonal coil to the board and it worked just fine.
On your diagram
http://www.nostalgiaair.org/PagesByModel...013236.pdf
I see another short coil above the RF coil. Maybe this is part of the original? Or maybe a seperate coil that is on the antenna loop?
Just make sure you ID the leads on the replacement fefore installing.
I see that you tried to find the break in the old coil, good for you. I was able to get lucky a few times and found the break 2 or three turns into the coil. Or found the break right at the terminal. But once you've unwound much of the coil it seems hopless. I have had some that were broke right at the inner side, and rewinding would be out of the question at least for me.
So to your original question, I'd say that the generic replacement would work fine.
Good luck,
Gary.
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 2481 online users. [Complete List]
» 1 Member(s) | 2480 Guest(s)
