Philco Hippo Speaker
I'm currently doing a Hippo right now and accidentally poked a hole in the speaker. Would it be better to recone or replace the speaker? Also I was wondering if anybody has ever made re-cap kit/list for specific radios. Since this is my first restoration, should I be replacing the wiring and resistors too?
How big is the hole?
If it is not too big you can repair it. Carefully put back as much of the speaker material as you can into its original position; use some toilet paper (don't laugh) to fill in any remaining gap. Glue all with FABRIC glue which you can obtain at Wal-Mart or any fabric store.
The toilet paper worked perfect, I used that and some silcone based glue for flexibility. Not sure how well it will sound. I'm still restoring the chassis. Wow, some sloppy soldering in there, might re-wire the whole thing.
Hi Tony,
Some places like Just Radios will make upa cap kit for your particular radio.
If you are going to be doina a lot of sets, it would be cost effective to order a cap assortment. Just Radios, Radio Daze etc have the assortments of the most popular values you'll need.
For now, just use the diagram, and make a list.
Gary.
tony2K35, hi. When you make up the list of caps check it twice for values. Radio Daze has a minimum order and I know a guy that had to order three times as he kept on screwing up on a .001mfd (.1mfd one time, .01mfd the next) so he had to order more then he needed. Well, ended up with a large selection of caps ($15.00 worth of spares)! PL
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 3369 online users. [Complete List]
» 4 Member(s) | 3365 Guest(s)
AvatarAvatarAvatarAvatar
