Radio back board pins
Hi,
New here and thanks for having me. I was wondering if anyone knew of a supplier of these back board pins. I am restoring a 48-1201 and found only one pin.
Mike
http://i1220.photobucket.com/albums/dd45...33642f.jpg
Welcome to the Phorum! You could post a notice in "Wanted Ads" section. Might also try David Frush at parts2many@aol.com. He has a lot of different types of non-electrical parts. Also take a look at this http://www.renovatedradios.com/parts.html#trimounts . Not exactly the same as pictured but might do the job?
I don't know of a source for them but they used to be called tri clips because of the three legs they have. You may try an auto parts store or an outfit like McMaster-Carr, or one of the outfits that sell restoration bits for vintage cars.
Hey Mike
If you do run into a source for them let us (Phourm) know. The question does come up from time to time.
TNX
Terry N3GTE
There are currently 10206 online users. [Complete List]
» 3 Member(s) | 10203 Guest(s)
