46-1209 Phono
Does anyone know what the original cartridge was that was used in this model? A customer brought in a Shure P70 that they say came from it but I can't crossrefernce it. H**l, I can't even find a picture of it.
I figured out that this model uses either the D10 or D10A phono which means there are 2 different cartridges used, either dynamic or ceramic.
I had a customer bring me a Shure P70 cartridge that they said came out of this radio/phono and I had a hard time identifying it. Well, its a crystal cartridge so they must have the D10 changer. Now I just have to cross reference it and see if I can find a replacement.
West-Tech Services has several photos of phono cartridges on their site:
http://www.west-techservices.com/p1.htm
Maybe this will help?
There are currently 10029 online users. [Complete List]
» 3 Member(s) | 10026 Guest(s)
