Chassis Restore Recommendation?
Hi Guys,
I would like to have my 660 chassis overhauled. I used to use Russ Turner here in Palm Springs, CA. for several other radios over the years. He was very good but ill health has forced him to discontinue this venture. Can anyone here recommend someone that's not to far from me?
Greg
Have you tried contacting the Southern California Antique Radio Society?
http://www.antiqueradios.org/index.html
They should be able to point you to someone in that area...
I have not. Thanks Ron.
There are currently 10567 online users. [Complete List]
» 3 Member(s) | 10564 Guest(s)
