Identify these 2 radios?
Does anybody know the model #s for these? The first is an RCA and the 2nd one is a Crosley Fiver, but I don't know the model #s.
Thanks
Eric
The Villages, FL
Crosley looks like this one: http://www.radioatticarchives.com/radio.htm?radio=571
Sorry, can't find anything on the RCA. It's a very unique styling. I can't understand why it isn't in RadioAtticArchives.
That looks like it. As far as the RCA, it's on its way here. I'm thinking that it will be marked somewhere or I'll look it up by yht tube compliment.
Eric
The Villages, FL
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
