HELP ID this Radio
Can anyone tell me the model number of this radio? It is a Truetone set by Western Auto.
Thanks - Jim
[attachment=2256]
What's it say under the dial?
Truetone.
There are currently 7083 online users. [Complete List]
» 2 Member(s) | 7081 Guest(s)
