37-620 Restoration
While waiting on parts, I tried painting a tube shield. Then it occurred to me that the paint prevents a good ground through the holding clamps. Is this an issue? How do you guys handle this? Just not paint the bottom where the clamp is?
tks, Vic
http://s1275.photobucket.com/user/vgibso...6.jpg.html
Are you using heat resistant paint?
SOme of those tubes get pretty hot.
murf
It is Krylon Rust Protector Metallic Finish - Satin Nickel. Oh boy. Am I asking for problems? I cant find any specs. on heat. They have a high heat aluminum - but you have to sign over your mortgage to buy a can... plus I still wonder about the shield not being properly grounded through the paint. What were they originally coated with?
Vic, I have used krylon with good results. I do mask off the very base to assure a good ground.
Jerry
The shields were originally tin plated.
I have found that the Krylon Satin Nickel does conduct. I've sprayed some shields with Satin Nickel and not had any issues of the shields losing their effectiveness.
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
There are currently 3019 online users. [Complete List]
» 1 Member(s) | 3018 Guest(s)
