Tube Suppliers
I am restoring a Philco 38-12 and in need of the following tubes, 41, 75, 78 and 6A7. Used tubes are ok. Any suggestions what suppliers would offer the best pricing? Thanks.
Google ESRC Tubes.
Hey BA,
Just where is "Way over yonder"? Icon_confused:
Eric
The Villages, FL
Pyeongtaek, Korea. About 50 miles S. of Seoul
Wow! What brought you there, the military?
Eric
The Villages, FL
Getting back to tubes,
VTI in Florida is a great place run by an honest guy.
http://vacuumtubesinc.com/
DG
Pacing the cage...
I'll second Conelrad's recommendation on VacuumTubesInc.com.
I've ordered from Jim a couple of times and also spoke with him on the phone once or twice. He's super nice and super helpful.
I'm also restoring a 38-12. I found some great prices, as always, at AES. http://www.tubesandmore.com/
Eric
The Villages, FL
Bob Dobush at FindATube has been reliable with good prices: http://www.findatube.com/
Must add Alton Smith down in Louisiana, fast freindly reasonable.
http://antiqueradiotubes.com/
