49-906 FM hum
I just finished my 49-906. Replaced all caps, out of range resistors and a few tubes. Alignment was done also.
AM is good and strong-no hum. FM picks up a few stations but has a hum all across the dial. It does almost go away when tuned to a station.
What did I miss?
http://www.nostalgiaair.org/PagesByModel...013675.pdf
Eric
The Villages, FL
You might try changing the 14F8 converter tube. If it has heater to cathode leakage, then the AC voltage for the filament will FM modulate the oscillator, causing a hum. It could also be the 19T8 tube, since different diode sections are used for FM.
Thanks, I'll try a swap and let you know.
Eric
The Villages, FL
That did it! The 19T8 made a difference.
Thanks, Mondail,
Eric
The Villages, FL
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
There are currently 2613 online users. [Complete List]
» 1 Member(s) | 2612 Guest(s)
