Great tool for cutting veneer
I recently got one of those Soniccrafter tools as advertised on tv. The kit came with an attachment called the Sonicshear. Looks like a pair of scissors that fits on the tool. I was replacing some mahogany veneer on a radio cabinet and decided to try it out for that purpose. First I tried it on some old, dried out un-backed walnut veneer I had stripped off of an old Philco console. Zipped right thru it. Nice clean cut, no chipping or splitting. So I tried it out on a piece of my new, paper backed veneer. Cuts like butter. Very clean and fast even against the grain. Even used it to cut a few small patches. Worked great.
Maybe everyone else knew this already, thought i'd pass it along anyway.
This the one? https://www.rockwelltools.com/en-US/Uni-Fit-RW8943.aspx
Yep! That's the one.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 3610 online users. [Complete List]
» 1 Member(s) | 3609 Guest(s)
