GOODYEAR WING RADIO
Yesterday I bought [as if I really neede it] a mid to late 30's radio. It has a White plastic cabinet ,really ART DECO, chassie is removed from the bottom . SIx tube one is a Ballas tube, I paid $2 at flea market, can't seam to find a model #, On the chassie is stamped
{ 3 B 190-8} is this the model # Anyone have an idea?
Bill,
You might find a model that matches here:
http://grillecloth.com/sylvania/tubelist...ubmit&db=5
http://grillecloth.com/sylvania/tubelist...ubmit&db=1
Carl
Northern Panhandle, WV
There are currently 7876 online users. [Complete List]
» 3 Member(s) | 7873 Guest(s)
