Threads: 113
City: The Villages
I've been getting a lot more FM radios lately and I do an alignment per instructions, but I know I'm missing something. Do some of you have a sweep generator for FM alignments? I'm thinking of getting one but I don't know what to look for. Can you guys give me an idea?
Is this the kind of generator that can be used? http://www.ebay.com/itm/BK-Precision-Fun...2a3066ce8b
Thanks
Eric
The Villages, FL
(This post was last modified: 08-25-2013, 05:58 PM by Eric Adams.)
Threads: 14
City: Irvington, NY
No Eric, that generator won't work for FM alignment, It is a low freq sweep/ function generator, not an RF sweep generator.
This is the kind of sweep generator I use for FM alignment. The HP 8601A is a great quality generator that covers up to 110 Mhz. They can sometimes be found on ebay for less than $100 and is well worth the money. This listing is a bit pricier but it gives an idea of what it looks like:
http://www.ebay.com/itm/Agilent-HP-8601A...3cd49dd516
Threads: 113
City: The Villages
Thanks for pointing me in the right direction, Mondial. I think I've got an idea of what to look for.
Eric
The Villages, FL
Threads: 113
City: The Villages
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
No good. That one covers 8000 to 12400 MHz !
The HP 8620C is also a possibility but you need to make sure it has the low freq 1- 110 MHz plug in.
I would still recommend the 8601A. It is not only a sweep generator but also a calibrated output AM-FM signal generator, adjustable from 0.1 microvolt to 3 volts of RF output.
(This post was last modified: 08-25-2013, 10:33 PM by Mondial.)
Threads: 113
City: The Villages
So that's all I'd need for all alignments? That's what I'll go after, thanks.
Eric
The Villages, FL
Threads: 14
City: Irvington, NY
Yes, the 8601A would be the only generator you would need for any FM radio alignment. It will also work for AM and shortwave alignment, but it may not go down low enough to align low freq IF's, so it would still be good to have an inexpensive AM RF generator on hand.
Here is a link to the service and operation manual, so you can get an idea of what it can do:
http://bama.edebris.com/download/hp/8601...08601A.pdf
Threads: 18
Whatever, pretty reliable inexpensive frequency counters are available to check the accuracy of aging signal generators, which always benefit from a recap/recarb job and should be left on for at least a half hour to stabilize, and of course be very careful about grounding. I have changed a lot of such old test stuff to 3 prong plugs and know my bench is wired properly. I do use isolation transformers where appropriate, so it's been a while since I was last knocked on my **s.
Threads: 113
City: The Villages
Thanks a lot, Mondial. I'll read up on it first before I pull the trigger.
Eric
The Villages, FL
Threads: 113
City: The Villages
Eric
The Villages, FL
Threads: 88
City: Tacoma
That's the same one you posted before. It's for microwave work.
Threads: 113
City: The Villages
Eric
The Villages, FL
(This post was last modified: 08-27-2013, 01:08 PM by Eric Adams.)
Threads: 9
City: Vieques, PR USA
State, Province, Country: PR
Eric, if you are doing plain-jane AM/FM restorations of simple sets from the 40s and 50s you can get by without a sweeper. The alignment is pretty simple.
I've done it both ways. And I stay out of modern circuits - haha.
Threads: 113
City: The Villages
I know what you mean, exray and please don't take offence, but I'm not a "get by" kinda guy. I like to dig in and learn as much as I can. So now that I've mastered AM alignments I want to be able to do a complete FM alignment.
Thanks
Eric
The Villages, FL
Threads: 9
Maybe I should back up and say aligning a 1947 Philco FM radio is quite a different study than aligning a 1979 Sansui stereo receiver. Its indeed not a "get by" thing on modern radios. Totally different disciplines. Just didn't know where you were 'coming from' in the original post.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 6214 online users. [Complete List] » 1 Member(s) | 6213 Guest(s)
