Philco 116x Speaker
Does anyone know if part number 32-9024-a is the correct speaker for my 116x?
The Riders Vol 6 lists it as "Cone and Voice Coil Assembly U-9 p/n: 36-3381.
Maybe someone else has more info.
The 116X uses a U-9 speaker, part no. 36-1162.
Hi Ron
Does the 37-116 use the u9 speaker also??
Tnx
No, the 37-116 speaker (type W) is 14 inches in diameter; the U-9 is 10-1/2 inches in diameter.
Nutz
New member
Philco 630csx power cord
New member
There are currently 2743 online users. [Complete List]
» 5 Member(s) | 2738 Guest(s)
AvatarAvatarAvatarAvatar
