Manual de radio zeniht modelo 765
Hello friends:
I'm buying a radio Model 765 zeniht bad that does not work I have seen that has broken a valve per photo I would like if someone has the manual handling of the radio and if someone also has the outline of the radio will be grateful as they I would like to restore. The purchase of the radio will cost me 350 euros.
locuspiolin, this link will get you to the schematic.
Jerry
http://www.nostalgiaair.org/PagesByModel...025284.pdf
