PHILCO 42-PT-96
Hi all, i have a PHILCO 42-PT-96 The cabnet is in bacd shape the photo finish is all scratched up any thoughts on what to do ?
[Image: http://i21.photobucket.com/albums/b285/VOWR800/1.jpg]
[Image: http://i21.photobucket.com/albums/b285/VOWR800/2.jpg][/img]
See the Photo-Finish links in the MISC section of my site for info on repairing this type of cabinet.
Thanks chuck
