model 57 station indicator
hi all,just finished the resto of a model 57,what does it have as a station indicator? mine just has 2 rosette type knobs,no pointer.anyone have one they can post a pic of? thanks,phil
This is from my radio. It's 9/16" OD made from cardboard about 1/16" thick.
Richard
[Image: http://i170.photobucket.com/albums/u250/...ointer.jpg]
that's a great help.i suspected it was sorta like my 84,cardboard,which i have a spare but the hole is too big,i'll use it for a pattern and punch a smaller hole,thanks alot,phil
There are currently 10285 online users. [Complete List]
» 2 Member(s) | 10283 Guest(s)
