Have you ever seen a Philco like this?
City: Kentucky
It's a Philco Signal Generator. Type 024. I picked it up at an estate sale today. Is it worth restoring? As you can see, it's missing knobs and has no power cord. I don't really know what to do with it. Are they worth anything?
Threads: 268
Yah I think I've some on ebay. Some are battery power may not have cord.
Threads: 27
City: Boulder, Colorado
Hi All;
Puhpow, I wish I had the money, I would gladly take it off your hands..
Just to see what is inside of it.. In other words, what Philco did to make a working Signal Generator..
I have never seen one of these Babies, nor do I know what tubes are in one of these.. Are there any schematics for this unit ?? I realize that You may not know any more than I do..
I have NO clue if it is worth anything or not..
Would You take some pictures of the inside ??
Maybe that is what I need to get my Philco 34 going, as that is what is called for to do the alignment and such.. I am not using a Philco Signal generator..
THANK YOU Marty
City: Kentucky
Threads: 92
City: Clayton, NC
Believe that your Radiola III sig gen is a "homebrew" sig gen. The one who made it used a Radiola III cabinet to house it.
City: Kentucky
Aha... that makes sense. This guy had a ton of stuff. Several home brew items. They filled up my truck.
City: Kentucky
Threads: 92
City: Clayton, NC
I could spend hours amongst "junk" like that. It's even better when the old-time radio guy is there to pass knowledge.
City: Kentucky
Sadly, he passed away. I never knew him. I sure wish I had... he had loads of cool stuff like this. I got most of it today. I posted a thread in Ron's Bar and Grill with a partial list. His family was going to throw it all away.
Even with my truck full, I left so much behind that I feel bad. He had boxes and boxes of old resistors, NOS caps, tuning caps, etc.. his basement was full.
(This post was last modified: 09-08-2013, 09:16 PM by Jamie.)
Threads: 92
City: Clayton, NC
Well, do his memory right and research what you have. It sounds like you should be able to set up a nice bench to repair/align the old sets.
I am confident that a schematic exists out there somewhere for your Philco Sig Gen.
Chuck's site is a VERY good place to start!
Threads: 268
Looks like a battery job. Your missing the #30 tube two D cells and 45v B battery.
Threads: 27
Hi All;
PuhPow, You should see if you can go back and get another truck load, before they do throw the rest away.. If I had a truck I would..
THANK YOU Marty
Threads: 268
At some point it begins to be a space problem. Again don't ask me how I know.
Threads: 55
City: Evanston, IL
I may have service info on the small simple Philco sig gen.
It was marketed to Philco dealers as well as Philco service
shops. Early 30s vintage, I believe.
Chuck
City: Kentucky
Thank you Chuck. I will be contacting you soon and purchasing the info.
As for going back and getting more, I can't. I am completely out of room, and quite frankly, overwhelmed with what I have already.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
