Restoring my 37-116. It plays now!
Threads: 88
City: Tacoma
I've personally found that (soaking in) Simple Green does wonders for knob residue. A toothbrush, applied while the knob is still wet, will get any stubborn leftovers. I've done this many times, and the knobs come out looking like new.
Threads: 18
6J5 is about as simple as it gets. Metal version must have pin 1 to ground with no other ties of convenience, glass versions may require shield. 6C5 can sub if you have one 99%.
Threads: 562
Threads: 268
Looks Good! Big improvement!!
Threads: 92
City: Clayton, NC
Very nice example, Mike!! And with the 6A5 output system!!
Threads: 562
AND it sounds like that with OLD WEAK (officially weak according to the tester) 6A5 tubes.
And I did buy the new ones off of Bob Dobush! I thought the originals would work but bought the newer anyway just in case.
(In fact I had to change just three tubes, two 6J5 and the rectifier.)
They sound terrific!!!
Well, now I need to take that oatmeal residue off and then try some of that "Wine'n'Dine" or "Feed'n'breed", forgot which one it is....supposedly it will rid me of the necessity to do the full resto one day, and, what's better - of thinking of it
Threads: 92
City: Clayton, NC
(This post was last modified: 09-08-2013, 09:07 PM by TA Forbes.)
Threads: 562
Really? What do they use to hold the rugs? And do they cover themselves in GoJo first and then rub against the radio?
Gosh, I'd love to see that!
Threads: 92
City: Clayton, NC
Yep! Really!!
City: Kentucky
Morzh, that radio is looking great! Good job! ..
Threads: 97
City: Poughkeepsie, N.Y.
Great looking radio......Job well done another one saved and able to sing again give yourself a hand!
Threads: 18
City: Mesa, AZ
'Tis but an far cry from "whence it was". ![Icon_thumbup Icon_thumbup](https://philcoradio.com/phorum/images/smilies/icon_thumbup.gif) glorious!!!
Threads: 562
Oh' c'mon guys, you make me blush - I just cleaned it with GoJo....any one of you would make this cabinet orders of magnitude more gorgeous.
It's just the radio is so beautiful it looks good even without proper cabinet restoration.
Threads: 92
City: Clayton, NC
OK.... I guess that means you don't want the "candy-gram" I was having the Rutgers Bikini-Radio-Washing Team deliver to you
Threads: 73
City: Riverside, CA
Users browsing this thread: 36 Guest(s)
Quick progress report:
Hi Rod,
Hello Tim,
There are currently 10277 online users. [Complete List] » 3 Member(s) | 10274 Guest(s)
