Philco 116X schematic
Went to nostalgia Air to print off the schematic for this radio and they only had two pages. The first page of the parts list is I believe missing and the photo of the the under side of the chassis if there was one . Does anyone have this schematic and would be willing to e-mail this document to me, I would really appreciate anything I would receive.
Your missing a lot more than that. If you want a nice complete repair package, "Go See Chuck".
Jerry
http://www.philcorepairbench.com/schematics.htm
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3506 online users. [Complete List]
» 3 Member(s) | 3503 Guest(s)
