seek instructions philco model 765
hello friends
Seeking the instructions zenith radio model 765 to handle.
A greeting.
Here is the schematic...
http://www.nostalgiaair.org/PagesByModel...025284.pdf
hello friends
Now I have the radio zenith scheme but I want the instructions you would have when you bought, for serving a knob or another.
A greeting.
I look like when shopping instructions before operating new
So you want the instructions that came with the radio when it was new? .. That could be tough to find.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 2853 online users. [Complete List]
» 1 Member(s) | 2852 Guest(s)
