RCA 100 cathedral
I made one final impulse buy today on a radio and now will have to behave for a while! I found this cute little RCA cathedral/tombstone on my errands today and couldn't resist bringing it home. It's a little four tube set similar to my Philco 37-84 (actually a bit smaller) and other than the missing 1-V tube, it appears all complete. I guess this is a late version of this radio as it uses a type 41 for an output instead of a 38.
How could you not?? Great radio! Good find.
That's an odd little muffin! I like it! Icon_thumbup
I knew RCA made that 38 tube for something!!! You don't see them used much at all 'cept for a car radios.
Nice find
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 2991 online users. [Complete List]
» 1 Member(s) | 2990 Guest(s)
