Need Philco 46-350 parts and advice
Hello everyone. I just joined and just acquired my first Philcos, a 46-350 and a 41-250.
I need the glass dial scale for a Philco 46-350. I also need to find some feet to replace what is left of the old ones. Any ideas? The four-section can was replaced with cardboard cans, so I also could use an old capacitor and support bracket/clamp.
Which paint color code do you think is best for the metal handle attachments?
Does anyone know the name of that exterior covering material? Do you also know a source for it? My 46-350 is OK, excpet for one small hole, but similar material was used on some portable record players I have.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Hello,
I have a 46-350 parts set. I know I have a good dial glass. I will try to remember to look tonight to see if I have the other parts you need. I don't remember if I kept the cabinet or not.
Sean
WØKPX
Sean - someone else is selling me an entire part set, but thanks for checking.
There are currently 8483 online users. [Complete List]
» 1 Member(s) | 8482 Guest(s)
