Philco 46-350 in black
How common/uncommon are these models in the black stag? I've had one for years which needs a replacement handle which I can't find and haven't been able to find a suitable replacement for. I have 3 others in the brown, 2 of which have decent handles. Brown ones always seem to show up.
hi jim
can you show pic have not seen in black
thanks sam
If I can get my tempermental camera to work I'll post a picture later today.
Well, my bad. I've had this radio for so long seems I forgot the proper model number. Its actually a 49-607. Both models look so much alike that I've been confusing them for all these years> I feel embarrased.
It's OK. Icon_smile Philco made so many variations of certain models that it is easy to become confused. Icon_crazy
Thanks. I know what you mean with so many models looking the same. Kinda like their Transitones. Still would like to find a handle for the 49-607. Nothing seems to come close.
Philco 91 Tuning Condenser
There are currently 8414 online users. [Complete List]
» 2 Member(s) | 8412 Guest(s)
