Is this a Philco Grandfather Clock?
I spoke to the seller earlier in the week. If he still has it, I am going to look at it tomorrow as I am there on business.
What I cant tell is which model it is. Its hard to see in the pics, but the grill is different from any other Philco I can find here or online. It has two double vertical grill "slats" on each side where the ones I typically see have one on each side. The face looks a little different from a Model 570 also.
Is this authentic?
http://allentown.craigslist.org/atq/4167806101.html
I took the photo of the front of the set and greatly turned up the luminance so I could make it out.
My vote is for a Phranken-Philco and not a legitimate, authentic set. Looks like someone combined the case of a Philco grandfather clock, the front panel of a Model 60 console, a non-original clock face (probably movement also) as well as a Model 60 chassis and speaker to make an odd combination.
I tend to agree with Ron that
it's a Franken-Father.
Or if you prefer, The Odd Father of clocks.
Decent job though.
Chuck
Thanks, I'll pass on it.
Philco 91 Tuning Condenser
There are currently 2862 online users. [Complete List]
» 1 Member(s) | 2861 Guest(s)
