Need to change the needle on my turntable
Hey guys ! I need to change the needle of my turntable but i dont know where to buy one for this model.
http://www.amazon.com/Philco-Classic-Tur...+turntable
Thank you guys !
"Needles" for that model are sold on the same Amazon page that you posted.
Pete AI2V
Pete AI2V
Yuck, a China junk Philco record player. At least you can get needles for it, but don't count on the mechanism lasting very long.
Philco 91 Tuning Condenser
There are currently 2511 online users. [Complete List]
» 1 Member(s) | 2510 Guest(s)
