40-508 grill cloth
evenin' gents,just finished the chassis resto on this one and now i need the grill cloth,the pic here is a bit iffy,anyone have a better picture or know of a source??
thanks,phil
by the by,that speaker will make some thunder!!
Hi
What you want is GRC-27 from Radio Daze.
EDIT: I erroneously stated earlier that Grillecloth.com no longer carried this pattern...turns out I was wrong; they DO still carry Pattern 27. It is omitted from their Flash animation showing "all" (actually most) of their patterns...which caused me to assume they no longer carried it. But if you look at his Palette #1, or at his price list, it is there.
I apologize for the error. It is great to know it is still available!
hi ron,ordered the grill cloth,will shoot some pics when installed,thanks,phil
hi ron,cloth in and radio is back together,i'm not going to refinish as it's in pretty good shape,maybe i'll do the top later,i'll take pics tomorow when there's more light. do you want them posted here or emailed to you?
phil
There are currently 4118 online users. [Complete List]
» 3 Member(s) | 4115 Guest(s)
