Philco 51-532
Do you have any idea where I can find these IF cans (2nd IF 32-4240-2 and 1st IF 32-4160-6)? They both are in this model 51-532 which has a terrible firestorm.
I’ve never repaired a 6 prong can before and I broke the hair-like wire trying to get a capacitor reading on the other one. I am certain at this point it is the 2nd IF can that has the 6 prongs that is the culprit. But now I need both.
Thanks in advance.jim
