37-620 RF Transformer
I have a 37-620 that was working after restoration but now the broadcast band is down. I isolated it to the RF transformer part number 32-2108. The primary appears to be open. I have no experience with winding transformers with mag. wire.
Is there a place to buy the part? If not are there step by step instructions for winding your own? Also would a different RF transformer part number work as well?
Thanks for any help
Check here: http://www.philcoradio.com/resourceb.htm#v
and you can put a Wanted Post up in case someone on the Phorum has one.
There are currently 7268 online users. [Complete List]
» 1 Member(s) | 7267 Guest(s)
