I just bought this Serenader
            Like many of you i can't stop buying these radios. I have 14 consoles in the basement and four in the garage. and I still look on kijiji every day for a good deal.
I have to sell some in order to make room for morel.
Here is my latest find .It is a Serenader made by Dominion Electrohome. I had to get someone else to find the schematics for me because they are listed under Phonola.
Good looking console.
I had a battery set, also a Serenader, where the cabinet looked identical to the one you just picked up. I sort of wish I would have kept it but I had less interest in battery sets back then. The one you have was obviously stripped since it is devoid of any shading whatsoever, mine still had the original finish.
