What are these Philco speakers?
I traded for these for two reasons, #1: they are Philco and old; #2: I can't find another pair of these speakers online. But, I can't find a model number.
Can anyone give me a model number and approximate value?
As they have the Philco-Ford logo, they are no older than late 1960s. Possibly even early 1970s.
Collector value is nil to not much, I'm afraid.
If they are 32 ohm speakers, then I have a Philco AM-FM receiver that would work with them. These look very 1970s to me, though, and my receiver is a 1966 model. I probably would not have bought the receiver had I known it was designed for use with 32 ohm speakers. Icon_thumbdown
See that's my problem. I can't find out what ohm they are because I can't find anything on them. Screen goes all the way around and doesn't come off. There are no numbers on them at all. Other than the Philco emblem there is no numbers or letters of any kind.
Measure the resistance in ohms across the two wires coming out of each speaker box. It won't be accurate but will get you in the ballpark.
The ohms on these speakers is 9.6
I kind of like those, kitchy but in a early 70s cool sort of way, a perfect match for an eight track player. I don't know about these speakers but in the Criterion speakers I have the speakers point upward towards a reflector and the tops come off when you undo some screws through the sides.
Radio "Shock" used to offer omni-directional speakers something like this in the early 70s.
Arran,
I'd wager you are correct about the reflector inside the Philco speakers in the OP's post. Made me think of the old Harmon Kardon HK-25. I think Panasonic also made a similar speaker. Must have been popular in the 1970's.
Well, they would work pretty well on any old tube amps with 16 ohm taps, and well in parallel an properly phased would do very very well an anything designed for 8 ohms in a mono setup. No guantanties on solid state gear which is much fussier.
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2085 online users. [Complete List]
» 4 Member(s) | 2081 Guest(s)
AvatarAvatarAvatarAvatar
