630 power transformer question.....
Hi Guys.....
On the bench as I write is the power transformer of a Philco 630. The original transformer has died and went to flux heaven. The replacement, a known good transformer (so far), needed the usual new extension leads and a trip to the painting booth.
What I need to know before installation is the idle current draw on the AC primary side of the transformer. Hooked up at 117 VAC, I'm seeing a draw of 160 ma. (+/- 10 ma.)
Is this number in the ballpark? Unlike new transformers, I know the efficiencies of these older units can vary quite a bit and before I go about installing this one, I'd like to get a handle on whether or not the transformer will be a good candidate.
All ruminations welcome...
...Jim
Sound OK to me.
The basic rule is, if your transformer does no smoke and faithfully converts voltages, whatever current it draws then on the primary is the good current. Otherwise, in case of shorted turns etc, you will either smoke or won't convert etc etc.
The idle current is simply 110V divided by the primary inductance's impedance which is your inductance in H, times 6.28, times 60 (Hz). Say, 1H inductance gives you roughly 370 Ohms which would create roughly 0.3A current.
Ok Thanks....
The transformer is working in the radio quite nicely.
...Jim
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
There are currently 3811 online users. [Complete List]
» 2 Member(s) | 3809 Guest(s)
