Philco 87 cap question
Take a look at this photo. I'm sure this view is familiar to someone. You see those caps coming off of those two coils? The third one (to the left of those two) has been removed by the last guy. Since a replacement would be easy enough, (1) Was there a reason to do this? and (2) Since the radio seems to work fine, do I leave well enough alone? And (3) the two remaining are paper caps, .1, with a resistor, 100 ohm, inside and should they be replaced? (The chassis has been recapped.)
[Image: http://i191.photobucket.com/albums/z309/...79fc0d.jpg]
http://www.philcoradio.com/tech/images/87.jpg
The reason probably was the capacitor either leaking grossly or shorting.
It is desirable to replace it as it is a decoupling cap, but it will work without it.
Now as to should you replace the other two....I would, as again, they are decoupling caps and are exposed to the raw power voltage, so if they go, they will possibly take something in the power supply (choke, field coil) with them.
Or you could try your luck.
Were they RC filter caps I'd say "if the radio works well, leave them", but in case of decouplers I am pro-active.
Thanks.....is that 100 ohm resistor, part of these caps, anything special?
Those decouple the RF to prevent oscillation. On my 87 all where leaking badly. What I did was cut the ground wire off of the old cap and solder in a replacement from the top lug and the other to ground. The new caps are small enough to hide under the old ones.
Good playing set when it's all fixed up!
I followed your instructions and it worked perfectly. The radio sounds great. Thanks.
I just restored a very similar radio (Philco 86) and it
had the same decoupling R-C networks (qty 3).
I chose to be pro-active and replace all three. I actually
removed them and replaced them with modern
100 Ohm resistors and modern 0.1 uF caps.
I saved the originals. Some day I may see if I can
clean out the center part where the old cap is and
replace it with a new cap. That would be the
best way to preserve the original "look".
Herb S.
Ithaca NY
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output.......morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
Philco 91 Restore Code ??
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
The shadow meter in the radio is responding to tuned signals but it never goes to a very small shadow even on strong sig...dconant — 01:01 PM
91H Code 126 Restore
Hi Nick, I am finishing up a 91 code 121 (one speaker). The dashed line is for the code 221 (2 speaker) set. I see there...dconant — 11:17 AM
There are currently 3994 online users. [Complete List]
» 2 Member(s) | 3992 Guest(s)
