need help naming this
hi guy`s and Brenda
I picked up this radio along with several others few weeks ago but I can not find any makers name. only printed on back is ALIGNSB16 ?
did bring up on my veriac for few minutes and all tubes lite and some static was not sure on antenna takes 5 24a 1 27 and 3 80`s
[Image: http://i1303.photobucket.com/albums/ag14...7a1864.jpg][Image: http://i1303.photobucket.com/albums/ag14...6afab4.jpg][Image: http://i1303.photobucket.com/albums/ag14...d3dd0b.jpg][Image: http://i1303.photobucket.com/albums/ag14...ac4294.jpg][Image: http://i1303.photobucket.com/albums/ag14...40d550.jpg][Image: http://i1303.photobucket.com/albums/ag14...068a05.jpg][Image: http://i1303.photobucket.com/albums/ag14...aaa07c.jpg][Image: http://i1303.photobucket.com/albums/ag14...833437.jpg][Image: http://i1303.photobucket.com/albums/ag14...2c3a94.jpg]
any help would be great thanks sam
Three 80s? That doesn't sound right... That tuning meter is kinda like the one I had on a Stromberg-Carlson.
Probably should be one 80 and 2 45's judging from the general age and rest of the tube complement.
Or it possibly uses a pair of 71As, #50s, or 2A3s, but it could be #45s. The set somewhat resembles a Stromberg Carlson, they liked to use tuning meters in some of their sets.
Agree, Stromberg Carlson
I love it.Icon_clap Nice looking radio. Do you have the shield for the RF section? It appears to have used one, perhaps you took it off for pictures. Looks like a lot of fun (or heart ache).
Jerry
Sam, This is a great find. What does it say on that meter? Something like Tune Matic? Joe
Joe
hey guys and brenda
yes i screwed up again
it is 1 80 and 2 45`s cleaned off to see better
ok so it`s a carolson model number ? pic`s of simaler one ?
jerry i have shield all complete
thanks sam
Sam, I've spent several hours over the last couple of days looking at radio photos across the web. The thing I've noticed is that Stromberg-Carlson radios with the meter have the meter movement 'swinging' from the bottom. Your radio meter movement swings from the top. I also haven't found (so far) a S-C with a meter in a large/tombstone cabinet. However, the way that your radios chassis is built is strongly reminiscent of some S-C's. There's even an Edison that looked similar. I'll continue to look but I think that once you open everything up there may be labeling inside the chassis. Two questions: What does it say on the face of the meter, and are those sliding doors on the front? Thanks, Joe
Joe
hey joe
thanks for the help i looked at all the carlsons none matched it has sliding front doors
the finish is really pretty good still except for legs and skirt that come off with is fixable i will get a good pic of meter monday it is at work right now it is a weston meter
thanks sam
Maybe it is an American Bosch model? That chassis looks like one I ran into in a photo, while researching something else.
By Jove, I think Arrans got it! The American Bosch 58A chassis even has "ALIGN6JM" on the back.
See http://www.radiomuseum.org/r/americanbo_58a.html
The radio doesn't have the meter, but that chassis looks to be the same. I wonder if the meter was an option or aftermarket. Joe
Joe
Looks like Sam's radio is missing the nameplate, which fits over the terminal strip that's exposed on his.
The Radiomuseum photo of the plate says not to remove without unplugging from AC outlet, which make sense since it covers the line voltage selection terminals.
I agree that the chassis is very similar, but there is a big difference: this one has more controls. Also is less ornate. I can't find pics of some of the other close models, but suspect it could be a 59 or a 60.
Brenda, I think you are right. The model 60 has the extra AVC tube and the tuning meter.
http://www.nostalgiaair.org/PagesByModel...028916.pdf
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
