Model Number?
I am working on a Philco radio for a friend. He said that it was a Philco 40-190, however the tube complement does not correlate.
It has the following tubes, 84, 41, 41, 7C6, 7A6, 7B7, 6J8, AND 1232.
The Philco 40-190 has a 7J7 in place of the 6J8.
Does anyone know the model of this Philco radio?
Thank you.
Oscar
NV3G
Hi Oscar
Probably 40-190. Icon_confused Allow me to explain.
Some 1940 Philco models started out using 7J7 mixer-oscillator tubes. Then Philco switched to 6J8G. THEN they switched BACK to 7J7.
Confusing, yes?
I do not know why they did this. I suspect they got a good deal on 6J8G tubes and used them up, then went back to 7J7.
There are currently 8607 online users. [Complete List]
» 2 Member(s) | 8605 Guest(s)
