Antique radio programming-on KBRD radio
FYI: If you like listening to the music that was being produced when our favorite Philcos were being made, you might want to check this link out. Several people are now using small AM transmitters hooked up to their computers to play this music on their home radios.
http://www.hezzie.com/kbrd/
Very interesting. Thanks for the link.
I'm listening right now to Frankie Carle - very nice. I like their humility;
"ninth best radio station". I don't suppose they will tell me the better eight.
Philco 91 Tuning Condenser
There are currently 6608 online users. [Complete List]
» 1 Member(s) | 6607 Guest(s)
