question about Philco bakelite that export british multi wav
Hello everyone,
I'm new here at Ron's hang out but . I have question about Philco bakelite happen to be looking at it was british export that runs on 200 -220 50 cycles . Far as model no on out side of the cabinet I had no luck.
Just Cabinet makers name or store that sold it J.S. atkinson scarborough.bottom edge is wood The radio is like 19 long by close 12 tall 9 in deep roughly
and had paper tag tied to a knob that said it was 1950s era . 220v 50 cycles radio . is ther any one that has photos of some of Philco exports also the cabinet was really square in shape also like a lot of the philco radio the cabinet top is shaped like square wave insted of being just flat middle is lower then the to ends --_-- if that helps and looks like mini tabletop console .
sincerely Radio Rich
P.S. is there a place on the web either then the attic that I might find photos to try finding the model no.
Hi Rich, and welcome!
I have some photos of British Philcos that I intend to post on my website, but frankly have not had the time to do so. But the pictures I have are of 1930s era models.
At this point I do not know where else to direct you for pictures, sorry. Perhaps someone else will chime in with an idea?
Hello Ron,
thanks for the info as I might have found help from the Brits .Well I found A british verison of The antique Radio forum Icon_smile .
sincerely Rich
P.S. I want to by the radio at second hand shop but I would like to know little about it before put down $80. for it. the guy selling it had it restored electricaly
Hi Rich,
Good to see you here. I am not sure but is theis the foru you found?
http://www.vintage-radio.net/forum/index.php
They were pretty helpful the one time I had asked them a question.
So the set you're looking at has been "restored" ? I wonder if he may have converted it to use 120v ? Or perhaps there was a provision for selecting input voltage? Maybe not, if it was for 50 cycles.
Let us know what you find out on it, or perhaps a photo even of you don't buy it.
Take care, Gary.
gary rabbitt Wrote:So the set you're looking at has been "restored" ? I wonder if he may have converted it to use 120v ? Or perhaps there was a provision for selecting input voltage? Maybe not, if it was for 50 cycles.
Take care, Gary.
Most European sets of that era had taps right down to 115 volts. France, for one, used 110-115 always in older sets. Not sure about the history of their changes and when they changed to '220'. That said, UK sets are often the "not-European" exception in being 220-240 only. But then again, Philcos made in the UK were often destined for the Continent.
Either way its a no-brainer. You can get a capable 240/120 converter for about 15 bucks.
Hello Gary ,
well here is a link to the set that I'm looking at to buy . it's a Philco model A547B Bakelite cased four valve (+ rectifier) superhet. Circa 1947. Valve line-up 6K8, 6K7, 6Q7, 6V6. Rect R52 (5Z4G).
The cabinet is in great shape and it's in original condition because they let me take the back off at the store .The sell got it at a estate sale the lowest price the guy will take for it is $70.http://www.vintage-radio.com/recent-repa...a547b.html
Also Xray to answer your question about the transformer I have this square D 100va step down or step up transformer laying around in my stuff .
http://www.grainger.com/Grainger/items/4R822
sincerely rich
P.S. I think that transformer should work just fine Icon_wink
Hey there they go with the plumbing again Valves I know why the radio was not running at the shop I had hook it to the water main Icon_biggrin not electric main
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 3311 online users. [Complete List]
» 1 Member(s) | 3310 Guest(s)
