Philco Power Cord Color
What was the color of the Philco RADIO power cords thru the years?
I have found several sets with black and white. What was the pattern if any?
All the 30s cathedrals I have seen so far (80, 20, 90, 70) had brown cloth wrapped wire.
I am sure there were others.
Brown cloth till '37 after that rubber.
Philco 91 Tuning Condenser
There are currently 6182 online users. [Complete List]
» 2 Member(s) | 6180 Guest(s)
