650B tone control values
Guys, I want to replace the caps inside my tone control. The part number from the schematic is a #30-4343. I don't see this one listed on Chucks site. I assume points 1 2 3 & 4 are as follows. 1 = open, point 2 is the first position back to the cap and so on for points 3 & 4? Thanks.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
I found it listed in the schematic as .01 .003 and .01 in that order. All listed under part #57. Am I correct?
http://www.nostalgiaair.org/PagesByModel...013824.pdf
-Brian
Yes, those are the correct values.
Point 1 - none of the caps are in the circuit.
Point 2 - shorts out the first .01 uF cap, reducing or eliminating bass.
Point 3 - brings the .003 uF into the circuit, leaving the first .01 shorted and adding just enough bass to make the sound mellow without reducing treble by any appreciable amount.
Point 4 - puts the second .01 in parallel with the .003, leaving the first .01 shorted; produces lots of bass, cuts treble significantly.
Thanks Ron Icon_wink
-Brian
Fixed! Much better!! Icon_wink
-Brian
Philco 91 Tuning Condenser
