Philco decal for 42-345
Does anyone make the Philco name decal that goes above the tuner for a radio that has already been restored? Any feedback would be greatly appreciated. Thanks!
Hi, welcome to the phorum! Check radiodaze.com, under reproduction graphics. Click Philco, it's on the second page.
Welcome to the Phorum!! Sykscraper has pointed you to the largest supply of Philco decals. Antique Electronic Supply also has a sheet of decals
There are currently 9716 online users. [Complete List]
» 3 Member(s) | 9713 Guest(s)
